Results 1 to 6 of 6
Thread: Advice on new clutch for a JZA70
    Default Advice on new clutch for a JZA70
    Hi everyone, i just purchased a JZA70 supra that is in need of a new clutch.
    Has the original worn out clutch in it atm and its slipping badly.
    Mods at the moment are: 3" from Ypipe back and an intake. Running stock boost.
    I'm after a good streetable clutch that i can slip. Plans later are to get it up to around 220rwkw so i'll need a clutch that could handle around that or 200ish mark, but i'll be driving it 99% of the time on the street.
    Im thinking a full faced organic should do the job, and I can get an exedy for a decent price.
    This is what exedy offer off the shelf:
    Heavy Duty Kit TYK-6571 HD
    Heavy Duty Button Kit TYK-6571 HDB
    Heavy Duty Cushion Button Kit TYK-6571 HDCB
    Welcome to hear any other opinions/experiences
    thanks
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    Default Re: Advice on new clutch for a JZA70
    cushion button and dont look back
    87' z20 Soarer - 1jz Gt35r -
    Just looked at the pricing on the cushion button rrp $1000+ !!
    I was told the full faced heavy duty will handle apparently 260kw @ flywheel. with 15%drivetrain loss will be about the max i'll need, so i'm leaning towards just getting that..
    Anything else i should consider under the $700 price range?
    For those that dont know jza70 = 1jzgte + r154
    Mar 2008
    inner west syd now!
    brass button with sprung center, tis a bitch to drive, but will handle powa.
    Mar 2008
    inner west syd now!
    xtreme clutches are cheap and good, bro is running one in his 154/1jz a70..thats where the above comment originated from
    ^^ thanks for that, sounds a bit much for what i'll be needing though.
    Spoke to Jim Berry from Raceclutch and it looks as though i'll be going that route. Bit dearer than an exedy (organic) but i think it will be worth it.
  1. JZA70 Clutch Problems
    By Shadow6 in forum Tech and Conversions
    Last Post: 15-01-2009, 10:13 PM
  2. 6M clutch advice - look'n for a new setup.
    By Johnzoku in forum Tech and Conversions
    Last Post: 26-05-2008, 11:40 AM
  3. MA70 --> JZA70 Conversion
  4. 4AGE "Heavy Duty" Clutch issue
    Last Post: 12-02-2007, 11:39 AM
