Originally Posted by
mullett
I may be wrong for the eastern states, but I know that in WA (at least when I was looking into it) you only need to fit the minimum emissions equiptment that that *car* came out with, or the minimum standards for that year. Hence cat is not required unless the car is built after 1986.
The info i was giving was also based on a straight NA swap, the std diff would never handle the power of a turbo motor, but would probably be OK with the NA motor unless it was badly thrashed.
The method of mounting the motor (to remove and replace the mounts) is just my preference because it's neater and keeps the loadings on the X member square, it's also easier to get engineered if they're re-welded.
Not having a go at you mate...
-RM.
