Results 1 to 4 of 4
Thread: re-applying seam sealer. A good idea?
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    Default re-applying seam sealer. A good idea?
    It will be for a road driven race car. (AE86. Oh dear, wrong forum)
    Shell is stripped bare, no sound deadener, most seam sealer removed. I have now got a full roll cage and a lot of stitch welding has been done all over the place. Most is still bare metal right now.
    I will start preparing for paint soon, but havn't painted a whole car before. I am now thinking maybe I should wipe seam sealer back into all the cracks (may hide some welds also) which may stop rust etc. On the side of one seam sealer product, it says it can be applyed to bare metal.
    A friends race car was sand blasted and painted white. A couple of years on, you can see the colour of rust coming up on all the edges and joins. Not something I want.
    Default Re: re-applying seam sealer. A good idea?
    as long as you can seal the whole seam. seam sealer is there ot act as a physical barrier to (mostly) water entering and wicking in the seam. but it will still get in from the other side.
    you could also use a brush and physically paint in the seams as well... POR15 the seams?
    Has a pet Grease Monkey
    Nov 2008
    Netherlands
    Or do both, say apply the sealant between coats of paint, but don't forget to leave drain holes!
    Dec 2008
    south australia
    terrolan hell, sounds funny but its what we use at holdens to seal between panels, white easy to paint over, brushable/ pokable into cracks and air dry, the only problem apart from water ingress into seams if you dont seal is sqeaking of panels
    I'm an atheist but it's not my fault it's the way GOD made me
  1. 1983 Crown + 7m-gte 5 speed good or bad idea?
    By LeaThaL in forum Tech and Conversions
    Last Post: 24-10-2006, 05:52 AM
  2. hydraulic handbrakes......good read for those into motorsport! ;)
    Last Post: 09-08-2006, 10:55 PM
