Whats your temp going up a long hill? If it constanly climbs I would be looking into it a bit more further! What thermostate a you using? I had a 7MGTE and I was using a 86deg thermostate. Also does the computer control the fan or do you have a thermo control to operate it? If your using a thermo control to switch the fan on/off set it so it comes on a couple of degree's above your cruising temp. Also I originally had 2 10" Davies Craig thermo fans with my 7MGTE and had problems controlling heat so I got myself the twin thermo setup from a Ford Falcon, worked miracle's.
PS Before you dive in to deep make sure your water system is ok (No clogs in water pipes etc, water pump ok, thermostate ok, radiator not gunked up with leave's etc) Goodluck!
