Results 1 to 9 of 9
Thread: MX83 Cressida - Turn Signals Not Working --- Help!!!
    Nov 2008
    Default MX83 Cressida - Turn Signals Not Working --- Help!!!
    Hey guys, been wiring up my headunit and ive run into a problem. The turn signals are not working.
    The lights and dash will flash with the alarm and the hazard switch, and the fuse for "turn" isnt burnt - but nothing happens when I flick the indicator - on the dash or the actual lights.
    When I was wiring the headunit I maybe cut a few wires I shouldnt have --- i.e. I cut wires that were plugged into a technics thing (i assume some sorta amp?) - I wouldnt think that turn signals would be plugged into that but?
    pps. can I remove that technics amp? does it serve any purpose other than the factory stereo?
    Thanks for any replies - driving without indicators is dangerous lol :S
    oh and does the car engine need to be running to use the turn signals? i cant remember if they worked on acc lol
    perth
    Default Re: MX83 Cressida - Turn Signals Not Working --- Help!!!
    try chasing the wires back from the indicator stalk and see if there all joined up, i take it the lights worked before the headunt install ?.
    Join those wires back up and see if they will work.
    Junior Member Grease Monkey chaserbuddy's Avatar
    Feb 2008
    the turn signal lights wont work if the hazard light switch isn't hooked up, maybe you did something wrong there, also make sure you check all the fuses. oh and i think they the lights only work when you have igntion on the "on" function. pretty sure they dont work on acc
    Nov 2008
    ^^^^^ it was the hazards --- werent hooked up cuz the stezza is out atm
    thanks heaps mate, saved me having to find a non-existant problem
    Junior Member Grease Monkey ollie83's Avatar
    Jul 2008
    Do you hazzrds not work aswell? I would assume they dont either, and i would check the plug behind the upper volume knob (slightly to the left of). You would of unplugged it to remove the top two screws that holds the whole unit in place.
    If the plug isnt in then a circuit cannot be created, and hence no blinkers!
    Jul 2008
    haha, you beat me to it it seems. good to hear you sorted it out
    Feb 2008
    no problem lol, atleast its all sorted now
    p00 powar Grease Monkey Jin~Jah's Avatar
    hehehe yep Hazard switch for sure... i've done the same thing a few times
    Quote Originally Posted by slimdusty
    Please try to be a bit more accurate with your fault descriptions next time .. if they work with the hazard switch, then it's not the hazard switch not being plugged in.
    Ignition ON, not ACC.
    Mos.
