Page 3 of 3 FirstFirst 123
Results 31 to 37 of 37
Thread: Suitable diff for KE30 with 4AGE
    Default Re: Suitable diff for KE30 with 4AGE
    Hilux at "G" Series thank you
    mine weighs in at atouch inder 80kg with the lsd, brakes and full on limslip
    KE38 - 2TG
    MS65 - 1UZ
    Junior Member Grease Monkey faulksy's Avatar
    Quote Originally Posted by emp?
    How much did the conversion cost if you dont mind? Want to weigh it up compared to the Borg Warner i got done for me for my old ke30...thanks
    thanks for clearing that up emp...i confused myself
    cheers faulksy...personally i'd only trust a t series to get you so far...i'm hovering around the 200rwhp mark with plans to get it between 230-250. The axles aren't exactly huge by any stretch of the imagination so im interested to see how they will hold up under the stress. I've heard of some people running an E series diff although im not sure about the particulars...apparently its lighter than the F & G series but i cant confirm this myself yet
    $220 for the diff
    $50 to get the mounts moved
    $60 to get the tailshaft modified ti suit
    LSD was $200 as well
    KE38 - 2TG
    MS65 - 1UZ
    Low rep 1st year Apprentice
    Feb 2008
    victoria
    banjo centre's come out from the front of the diff. rear cover plate does not come off. either way both are weak, i did two reasonable launches and my side gears were gone. note side gears do not make a diff whine it is bad tooth contact between the pinion and crown wheel that make noise and give no real indicatinn of when the diff will blow. i did the skyline conversion in my car. if you can do most of the part sourcing and angle grinding yourself you should get change out of 500 bucks. when doing it pinion angle is cruitial if you get it wrong it will throw tailshafts. borg warner lsd centres may not be as strong as hilux diffs (i dont know either way) but parts are alot more availible than T series. my mate broke about 8 axles with 120kw in a t series diff. i launch my ke35 @ 6 grand quiet regularly and my diff is still holding strong. my car is pumping 134kw @ wheels not enourmous power but its fun
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    3 year old thread....no one cares
    Hey mate, just wanted to say if you have the money go for the hilux or commodore diff. I have a commodore diff in my ke it cost be 1200 for mini spool different gear ratio and shortening. My first ke30 had a 4k with some head work, a webber and exhaust and went through two celica diffs. Maybe i was just unlucky and found two dud diffs.
    Last Post: 17-06-2008, 09:53 PM
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  4. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 09:13 PM
  5. Most suitable sized exhaust for 4age 16/20v
    Last Post: 09-02-2006, 06:48 PM
