Originally Posted by
e30-323ti
The Evo 4 (twin scroll TD-05HR) turbo would be a better bet than the earlier TD-05H, provided you don't need to rebuild it, or want to upgrade it (ie.change comp. wheels etc...) assuming you are going for a 2nd hand turbo, the Evo 4 one will likely have less km's on it also.
A nice Y-manifold to each scroll will work well on the 1G and spool quickly, and dam cheap to build.
A friends Evo2 rally car makes 200kw atw on a TD-05H 16g with a 34mm restrictor (running ~20psi).
Both are a lot tougher than the RB20/25 turbos which would also be a good size.
