Results 1 to 10 of 10
Thread: supercharging 22re
    Mar 2008
    Default supercharging 22re
    I'm looking into supercharging my 2.4 litre injected corona.
    Would a 4age supercharger be the best bet?
    Or go all aftermarket?
    Cheers guys.
    Default Re: supercharging 22re
    If you are doing it for fun and something to do, then go for it. And use an SC14 off a 1GGZE.
    If you are doing it because you think it'll be cheap, easy and make good power, you'll be severely disappointed.
    As peewee said.
    The 22r is a truck engine for starters. Also, it came turbocharged as an option from the factory, so that path will probably/possibly be cheaper.
    The 4a-ge has a SC12 supercharger, but too small for the 22r. SC14 is a better bet, but you'll need to look into fab work involved, how much boost you want to run, then if you need bigger injectors, aftermarket management, exhaust, intercooler...... gets exxy
    Work out what you want and what your budget is, and then see if it's realistic
    Mar 2008
    Thanks heaps ay.
    I lost my licence and need something to do for a bit of fun.
    The turbo route would be alright too.
    Or mayybe i should just do it properly and put a whole other motor in.
    Maybe 1G turbo. =]
    A 1GGTE will probably work out to be about the same cost (depending on how overboard you go during the install - on exhaust/ic prices, servicing/etc) as supercharging the 22RE, plus it will use less fuel, have a lot more power, be a lot more reliable, and last a lot longer.
    Or...if you have a fetish for supercharged coronas like i do...go the 1g-gze
    1g-gze Corona RT132 (Daily)
    RA23 Celica (Project under way)
    RT81 & MS112 (Still Thinking About It!)
    Wife thinks i'm mad (yep... she's right!)
    south austraila
    it all sounds good.. but why supercharge..
    i got 154hp from a 22R NA with carby....
    But if you must, then try here http://www.lcengineering.com/
    supercharge kit..
    [IMG][/IMG]
    & the turbo kit..
    [IMG][/IMG]
    Project: '82, GA61 XX
    oregon
    22re + S/C could equal a stump pulling good time....
    Torquey motor... add a blower and boost the low end torque even more....
    Team Awesome Carport Converter Pimpin_1JZ's Avatar
    Bunbury W.A.
    Those kits acctually look pretty good. Hmm might have to look into those for our rally car...
    1JZ MZ20 Soarer - 4AGZE KE70 Corolla - 4AGE AE86 - 4AGE KE70
    Jan 2009
    Dude ive put those sc on a few engines back in the day use the six pot ones they are heaps better but realisticly the power you are goin to want the engine wont last its a lot of stuffin round but hey thats how we all learn
    Life isnt mesured by the amount of breaths you take Its measured on the amount of moments that take your breath away
  1. Hilux 22R to 22RE Conversion Help needed
    By MrBags in forum Tech and Conversions
    Last Post: 09-03-2013, 12:38 PM
  2. AAV / IAC Connections 22RE Help pls
    By Tomee in forum Tech and Conversions
    Last Post: 27-09-2008, 07:16 AM
  3. 22RE BIG TROUBLES! cutting out mysteriously...
    By ROHANVII in forum Tech and Conversions
    Last Post: 21-07-2006, 08:04 PM
