Results 1 to 9 of 9
Thread: Alternative to ceramic coating ........ :P
    Jun 2007
    Arrow Alternative to ceramic coating ........ :P
    Remembered this the other day... but since I don't have time to design and run simulations, I thought I would let you guys know since I know what extreme's you guys will go to disprove this idea being replicated on Turbo exhaust manifolds as ludicrous.... lol
    4.2. Retaining Heat of the Exhaust Gas
    In order to retain heat of the exhaust gas from the
    combustion chamber to the catalyst, two measures were
    taken: The exhaust port has a stainless thin-walled
    insert (made of heat resisting stainless alloy) and the
    exhaust manifold has two layers of air layer for heat
    insulation and small volume thin-wall inner tube. This
    allows for the retention of exhaust gas heat from
    combustion chamber to the catalyst. Because of the
    heat retention, gas temperature at a catalyst upstream
    could increase about 140 degree C in the USA LA-4
    mode drive, improving catalyst’s conversion capability.
    Fig. 24 shows structure of the exhaust port insert and
    exhaust manifold.
    Quote taken from the SAE paper on the RENESIS Rotary.
    I don't believe they used this technique all the way from the Exhaust port to the catalyst but I can find out if need be.
    Yay! I'm an Automotive Encyclopaedia Hydra's Avatar
    Default Re: Alternative to ceramic coating ........ :P
    So it's really like putting a blanket on in bed - the 'trapped' air acts as an insulator.
    Ceramic coating is cheaper and easier.
    Quote Originally Posted by abently
    Remembered this the other day... but since I don't have the knowledge to understandit, I thought I would let you guys know since I know what extreme's you guys will go to try and make me understand something basic.
    what is the problem? it is a relatively common thing to do.
    the problem: catalysts take time to heat up.
    reason?: heat is removed from the exhaust gas by the COLD exhaust manifold, and COLD exhaust pipe, before the gas can heat up the COLD catalyst to abotu 300deg so it can work properly.
    during this time, the engines emissions are not "corrected" and this is a major let down of any car trying to pass stringent emissions.
    they use heat resisting (high nickel, high chrome) stainless in the port because it has slow thermal conduction. thin so it has small heat capacity.
    exhaust manifold. thin inner layer to heat up faster, and then air layers to retain that heat..
    all to make sure the catalyst warms up faster.
    gee ab, with your knowledge, i thought you would have understood it without having to post on toymods to get an explanation, it is just very very simple heat conduction theory.....
    as for alternative to ceramic coating... how about i let you explain the pros and cons of each.... or don't you know?
    Least it doesnt snore Backyard Mechanic Gary's Avatar
    JZX83
    UCF11
    Jun 2007
    Air at 20C
    Thermal conductivity: 0.0257
    Density: 1.205
    Air at 400C
    Thermal conductivity: 0.0515
    Density: 0.524
    Air at 1000C
    Thermal conductivity: 0.0810
    Density: 0.2772
    The EGT's from the RENESIS Rotary Engine aren't exactly below that of the 1000C safe limit for Turbine wheels (Reaches 900C in front of the Catalyst). So to say the results aren't reproducible to OEM quality standards isn't valid.
    they say the EGT's are above 1000C? i find that rather interesting... and a bold claim.
    Jun 2007
    No they don't.... obviously the Air pump plays an interesting role also in raising EGT's but unfortunately someone with an RX8 will have to datalog it as its not documented publicly.
    I believe the idea has merit given the right circumstances.
    i meant in regard to the turbines.
  1. Ceramic coating intake manifold
    By Joshstix in forum Tech and Conversions
    Last Post: 24-09-2008, 10:45 AM
  2. Ceramic coating on Cylinder Sleeves...
    By Kagetsu in forum Tech and Conversions
    Last Post: 21-01-2007, 10:13 AM
  3. Ceramic Coating Brake Calipers
    Last Post: 26-02-2006, 09:45 PM
