Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Thread: need help. 1jz problem.
    May 2006
    Default Re: need help. 1jz problem.
    My car did this when I did the conversion to Jza70, ended up being the ECU, it would start... run fine, then just drive like shit and pretty much die. I used an auto jza70 (I think) and it was all fine.
    Junior Member Grease Monkey COS25T's Avatar
    i have confirmed it is the ecu. im goin to change the caps but im not sure about what i need to buy. also what does the plug that comes out of the ecu do?
    Tasmania
    You will need the following:
    33uf, 35V
    15uf, 35V
    47uf, 63V
    220uf, 10V
    100uf, 10V
    Get these and find a TV repairman or have a go yourself or ask someone on here to do it for a carton and it will be done.
    More info here:
    http://www.toymods.net/forums/showth...or+replacement
    thanks mate. lookin at it now and the leaks look worse than they did last week.
    ^ theres also a jza70 manual ecu "without leaking caps" for $150 on ebay atm.
    http://cgi.ebay.com.au/Toyota-Supra-...QQcmdZViewItem
    pretty sure the seller is an old forum member too.
    Western Aus
    Quote Originally Posted by COS25T
    we are not all made of money. i dont want to spend 300 dollars on something i might not need. i want to make sure before i spend a couple weeks savings.
    we might not be made of money, but if you didnt have at least a little more than usual, youd be driving a camry, and not a car like yours.
    i had the exact same issue and its the ECU, once again, Terra Operative is repairing both mine and John CoFFee's for nix
    true but i changed jobs a few months ago and took a MASSIVE pay cut and since then everything that could go wrong has and now im a poor bastard
  8. #38
    ok guys i had my caps replaced today and didnt fix my problem. i dont want to spend money going backwards so what am i expected to pay for aftermarket ecus including tuning.
  9. #39
    Tasmania
    Once again swap ecu's with someone to ensure its not the ecu and the tracks are gone even though you have replaced the caps. You NEED to do this to rule out the ecu as the issue.
  10. #40
    i bought a new ecu today and problem fixed. paid 220.
    thanks guys.
    pete.
  11. #41
    dont throw away your old ecu. It probly could still be fixed.
  1. GZ20 1JZ speedo problem
    By gztwenty in forum Tech and Conversions
    Last Post: 25-05-2008, 04:47 PM
  2. 1JZ performance head build. Advice/help?
    By ReQuieM in forum Tech and Conversions
    Last Post: 09-07-2007, 08:08 PM
  3. 1jz to 2jz
  4. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
