Re: Toyota 3sge/3sgte Head Gasket thicknesses
dave the 560 and 570 are .8 of a mm and there are 2 others that are dearer that are .5 and .3 of a mm for sprint races if you wont to go this way
i still use a std head gasket even with 13.5 to 1 comp in NA form so for turbo the std 1 should be ok
Thanks for that. Last time I ordered them I forgot to write down the part numbers - doh!
When I went looking, I found 4 different ones but no way to tell them apart. As it is, the new ones I'm waiting to come in from Japan are probably the earlier model ones so I have to cancel that order tomorrow.
With 9.2:1 comp and 18-19psi of boost, we didn't have any problems with the head gasket, just the bore so I figured we should use the same style gaskets again.
Thanks for the info Glenn.
another thing dave ,your red top .is it still set up in in fwd or rwd as in water set up .are you taking water from the back of head to go to the radiator ,or have you blocked back and taken water from where the alternator bracket is ,as this is the rwd out let .this will determine what head gasket you get as the water holes are set up different in the 560 and 570 gaskets
We've got a header tank on the alternator bracket hole with a custom water pipe into the front of the motor where the water pump normally mounts. The back of the head is blocked off.
The water pump and extra plumbing has been removed due to external electric water pump to reduce weight/complexity. The oil pump has also been removed from the cam pulley system.
then you need to order the 570 altezza head gasket
Dave,
You still have some of those FWD gaskets around?
I need one for an st215 4th gen 3s-gte...
Yep sure do, have sent PM :-)
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
