Results 1 to 8 of 8
Thread: 4AGE what do i do with these?
    Aug 2007
    victoria
    Default 4AGE what do i do with these?
    hi everyone just wondering where a few hoses that are coming off the intake manifold are meant to go and something a friend called a Christmas tree on the remote thermostat?
    was told that i need to plumb the blocked hoses for the engineers certificate but i dunno where they go,
    here are pics of what i mean
    http://s241.photobucket.com/albums/f...erjoe284/ta22/
    thanks in advance
    joe
    If it moves and it shouldn't use duct tape.
    If it doesn't move and it should use WD40.
    Default Re: 4AGE what do i do with these?
    The ones on the throttle body are for power steering. I'd just loop a hose to make it look good.
    And i'd remove that christmas tree and put a plug in.
    The first one is most likely a temperature switch for the EGR. I'd remove it and fit a blanking bung in it.
    The throttle body ones - two (as bmak said) are for the power steering, but if you loop them you will get high idle; and the third runs to the air con idle up valve - buy blanking caps for all three and cap them.
    Mos.
    Put a ball bearing in the looped hose. Looks more like it meant to be that way
    Chiba
    I pulled the fittings out on the fittings I wasn't using on mine (a pair of pliers and a bit of twisting will do it).
    Then I tapped the holes and fitted grub screws with a bit of loctite.
    Junior Member Grease Monkey craigy's Avatar
    There should be one marked CC, this goes to your charcoal canistor
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    Aug 2007
    victoria
    ok thanks a bunch for your responses +rep for all
    Jul 2008
    ive got a spare set of stock block off plugs if youre interested...
    i live in inner eastern area (kew) btw
  1. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 06:53 PM
  2. 4AGE -> AE86 Conversion: Accessories question
    Last Post: 17-06-2008, 09:53 PM
