none, learn to search
				 4age 20 valve conversion question
				What model corollas does the 4age 20 valve slot into
without any modifications or any wiring or computer
problems.
 Re: 4age 20 valve conversion question
				I have been searching but was just after a more concise
answer. If its any different between the models for if any
models are easier than each other.
				One which came out with a 20v to start off with....which is a grand total of NONE which were sold new in Australia, only imported AE101 and 111 Levins/Truenos. Every other one will require modifications and new wiring/computer work.Originally Posted by morgan
				dude you are going about shit the wrong way, firstly RWD or FWD? secondly why do you want to fit a 20v? what do you want to achieve with this car?Originally Posted by morgan
ps. most people here dont like spoon feeding others search this shit has been covered 100000000 times in various forms
				Sorry about that, did not mean too.
I was looking at fwd and was mainly
asking if it bolts straight in for ae82,ae92,94.
And with the computer on these models if it
plugs in or has to be modified. I think it also
would be easier if it was efi in the case of the ae94.
				ok now this is where you use your brain
you have a 20v 4a and you want to put it in an ae92/82..... holy snapping duck shit batman they have 4a's as well yes it will sit on the mounts and everyone will be happy
no it wont plug in.
				Do you have all of these cars? If not then be specific on which car you do own or which car you want to put the motor into. If you own none then specify that.Originally Posted by morgan
Not particularly. You use almost none of the body loom and replace almost all of the engine loom with that of the donor engine.Originally Posted by morgan
eg body loom you use:
- Instrument wiring
- Alternator wiring
- Starter motor wiring
- EFI Main
Engine wiring;
- Use the wiring corresponding to the motor it is using
....Then if I do a 2 minute google for "ae92 corolla 20 valve conversion" I get this http://www.4age.net/tech/20v/index.htm guide on how to do the conversion.
Now i'm dancing with a midget under a rainbow. The sun is out and shining brightly.
ps; welcome to toymods.
				Does the 16V have the same requirements? Its for my sisters AE92.
