Results 16 to 22 of 22
Thread: ma61, toasted LSD??
    Default Re: ma61, toasted LSD??
    If you have a worn factory LSD you'll need to send it to a diff shop, unless you already have experience rebuilding diffs (I'm guessing not). Given its age there's a good chance the clutches will need replacing in which case a TrueTrac swap would be more economical and effective.
    Either that or just live with it. The 5M-E isn't known for its ability to fry tyres.
    vic
    MA61 LSD,s are shit full stop , not enough clutch area inside them , they have splined side gears(not the axel spline) to take a splined steel clutch plate but theres no splined plate just spacers.
    Only RA40 GT lsd centres have the splined clutch plates and are not made anymore
    When you use one in a live axel diff, even a good condition one they single leg sometimes.
    I feel they are better suited to IRS setups as the bog down of rear helps the LSD work better.
    Dave
    Mar 2008
    inner west syd now!
    its LSD , i should of known, because it always leaves a pair on the grass out the front yard, steep driveway+reversing=lots of wheelspin at times, but i was cleaning the rear cover and boom, big LSD sticker on it!!
    will Saf-Xa be ok to put back in it??
    wog
    Junior Member Grease Monkey chaserbuddy's Avatar
    Feb 2008
    yes should do fine. I think the previous owner might of said its an open diff so you wouldn't get your hopes up and then realise how shit the lsd's are in toyota's...
    Mar 2008
    inner west syd now!
    i put Castrol LSX90 in it, it locks up and bit more now, but its still beyond its use by date, it goes from LSD to open when it feels like, its quite amusing!!!
    arse and a half to get the filler bolt out, ended up stripping it a bit aswell!!!!
    thanxs guys!
    May 2008
    try shimming it....Ive shimmed my spare LSD cant wait to try it out
    1992 - JZA70 STOCK - SOLD
    Quote Originally Posted by GA70H_92
    cool let us know how it goes, got any extra pics or info?
    what did u make the shims from etc?
    i would be keenly interested
  1. ma61 front end upgrade writeup.
    By nb86 in forum Tech and Conversions
    Last Post: 22-07-2009, 11:24 PM
  2. Replies: 27
    Last Post: 09-01-2007, 02:56 PM
  3. MA61 – GH Sigma LCA Upgrade - Negative Camber + Extra Track - GUIDE
    Last Post: 07-12-2006, 12:56 AM
  4. Buying an MA61 (Calling all ma61 nuts)
    By Sam Red Rolla in forum Tech and Conversions
    Last Post: 17-10-2006, 06:19 AM
