Results 16 to 25 of 25
Thread: Saber Gauges - Oil pressure stupid reading>?!?
    Default Re: Saber Gauges - Oil pressure stupid reading>?!?
    Between 50-80 beyond idle.
    even 80 is pushing higher oil pressures.
    Act
    i've got sabers and never really have a prob with them.
    I wish I saw 30psi at idle, the old 7M only sees about 4psi at idle if that
    vic
    Yes a non rebuilt 7M has little oil pressure at idle i see about 6 Psi hot summer idle. Keep the 20 /50 oil in them for summer .
    Dave
    i get 30 psi at idle in every 7m ive owned (taken reading from sandwhich plate)
    i do see about a 20% lower pressure when taking readings from the oil gallery in the block where factory sensor goes though.
    im running -8 lines to my remote filter location so not sure if thats the problem.
    mate with full built motor sees close to 80 psi cold oil pressure (this is on a rb26) and if he revs it up while cold - goes up from there!!
    Signiture edited..... Read the Rules
    Act
    mine is a re built 7M I'm in the same boat as you disturbed -8 lines on the remote filter and oil cooler.
    I'm not 100% here mine is picked will double check either way I have been thinking of shimming the oil pump.
    working hard Backyard Mechanic
    my 4agte idles at 60-80 on startup then down to 40psi when its warm..
    Metal Guitarist 1st year Apprentice AE35's Avatar
    I'm suprised you people havent checked the resistance of the gauge compared with the factory unit in reference to the oil pressure gauge.
    Are you using a compatible sender or the factory sender?
    1974 Toyota KE25 Corolla | Worked 5K | Twin Dellortos | Extractors | Sports Exhaust | - Memorial Car/Restoration Project/Weekend Car
    1994 Mitsubishi TS Magna | V6 | 5 speed | - Daily Driver
    Act
    Im using what came with the saber guage
    ^^ do u find/thing that the -8 oil lines to the cooler and remote filter are too small?
    i was 2 scared to plumb the cooler in as i thought -8 was 2 small and didnt want to invest any more money in -8 fittings incase i end up going -10 or -12. (speedflow fittings are fuckign ewxpensive)
    Act
    yeah my oil cooler set up with remote thermostat cost me a fortune, I haven't had any problems with it all, and I know it flows very well from the odd leak I've had.
  1. Replies: 3
    Last Post: 29-05-2007, 04:18 PM
  2. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
  3. [urgent] oil pressure sender types - 100kw sender to work with aftermarket guage??
    Last Post: 20-12-2006, 05:32 PM
  4. engine pinging
    Last Post: 15-12-2005, 12:15 PM
