Results 16 to 23 of 23
Thread: 1GGTE ECU overheating
    May 2008
    Default Re: 1GGTE ECU overheating
    there are 3 types of 1GGTE
    GEN1 ECU PLUGS are "fatter" and yellow Colour
    GEN2 ECU PLUGS are limish/yellow and slim
    GEN3 ECU PLUGS are the same size as GEN 2 but Grey
    I once had and also seen on ebay 1GGTE ecu identical to the gen 3 in plug size but yelloish green yours seem to be the fatter type after looking at those pics in your other thread leaning towards gen 1 ecu
    1992 - JZA70 STOCK - SOLD
    Quote Originally Posted by Jabtronic
    It's all Gen 2 engine/ECU/loom in my GZ20 soarer. No injector pack.
    But Gen2 injectors are supposed to have an injector resistor pack...they're low impedance injectors.
    Aren't there some gen2.5's with hi impedance injectors?
    Yellow injectors = low = needs resistor pack
    Green injectors = high = no resistor pack
    Not sure to be honest.
    Junior Member Backyard Mechanic VasH's Avatar
    I'll test the resistance tomorrow, will also clean up some of the manifold grounds etc.
    And thanks for the offer Vash, I don't really want to get the stage of swapping looms etc, for that much trouble I'd just throw a 1JZ in there instead. And yeah, I hope your ECU is still ok but if it's fucked now I'll reimburse you for it
    No worries man if its comes down to it and you put in a 1j i might be interested in your 1g
    1989 JZZ20 Soarer, 1JZGTE - The Project
    1984 YN57 Hilux, 4Y - The Daily
    That's a lot of work to do just to avoid wiring in a resister pack in the B+ suply to the injectors.
    May 2008
    that ECU you have is like the one in Jackels car and he has a resistor pack for the injectors!!
    hey jarrad i think yours does have an injector resistor pack as mine does too and i just looked at one of the photos of your engine bay from the jap car show and youve got one maybe its knackered and causing the problem?? heres a pic to give you an idea its a little metal thing with fins like a heatsink
    Shot at 2008-12-23
    Maybe borrow jakeys see if that helps??
  1. 1NZ-FE ECU & Ignition barrel problem
    By progkamol in forum Tech and Conversions
    Last Post: 20-03-2009, 01:24 PM
  2. 1ggte new ECU out diagram
    By Rosie in forum Tech and Conversions
    Last Post: 30-06-2007, 10:07 PM
  3. 4agze fault codes & diagnosis + Pulley
    By Poggy in forum Tech and Conversions
    Last Post: 01-05-2007, 11:11 AM
  4. Can a ECU be tested?
    By Gibbon in forum Tech and Conversions
    Last Post: 20-01-2007, 11:04 PM
  5. Aftermarket ECU for 1GGTE
    By Adash=P in forum Tech and Conversions
    Last Post: 09-07-2006, 02:25 PM
