Results 1 to 7 of 7
Thread: Ga70 1ggte Injectors
    Aug 2008
    cheshire. uk
    Default Ga70 1ggte Injectors
    Hi I need some advice on injectors.
    I'm running a single big t4 turbo and starvation is becoming a problem.
    I have upgraded the pump to a walbro 250lph.
    I have been told that the injectors are high imp by one person and low by another so im now confused (easy done).
    Are they high or low and what am i looking for in replacements ( Prefarably cheap!)
    Thanks
    Has a pet Grease Monkey
    Nov 2008
    Netherlands
    Default Re: Ga70 1ggte Injectors
    Don't go by hearsay if it's so easy to find out and be sure: grab a DMM and measure resistance of your current injectors!
    You should be seeing about 2-4 ohms for low imp, over 10 ohms for high.
    Aug 2008
    cheshire. uk
    Thanks
    Ijust need to find compatible larger cc replacements
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    A few link to review
    http://www.toymods.net/forums/showth...ance+injectors
    do a quick search and you will find lots of info
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    Aug 2008
    cheshire. uk
    Quote Originally Posted by TheToyman75
    Thanks thats a great great help abeit a lot of bs and arguing but i read the post and i get it that you found these:
    Nipondenso Part Number 23250 74160 as fitted to the N/A 3SGE - Generation 3 (SW20 MR2)
    They are rated at 372cc @ 3bar and are 13.4 ohm so just under 20% bigger than the stock 1G injector so will work great with a signal bender like the Xede.
    Now for a new stupid question.
    ????????? What's a signal bender ???????
    (I'm feeling like on now this it a new learning curve why did i stick with a 1g?)
    Leem,
    A signal bender is a term used for a piggy back style or interceptor style ecu. I use and prefer the Xede over anything else n the market as it is capable of controlling fuel, ignition, boost and supports the addition of a Map sensor for greatly imporved mapping over the AFM signal.
    My 1G runs like a dream and is fantastic on fuel now that it has the Xede. Not sure what sort of suport they have in the UK but there is bound to be something local.
  1. 7mgte injectors on a 1ggte
    Last Post: 13-06-2007, 04:52 PM
  2. JZA80 Apexi PowerFC with Sard 1000cc injectors problem, HELP!
    By Sicarius123 in forum Tech and Conversions
    Last Post: 22-05-2007, 09:22 AM
