well next remove the cam shafts and put them in order somewhere, do this by removing the head caps off them in a outward spiral start in the middle and spiral out. then you can start removing the head studs same spiral pattern as above. example i have done it heaps with 4age engines so i will use that as a example
inlet side
8 4 1 6 9
7 3 2 5 10
exhaust side
and replace them in the same order when you are puting them back in
