Results 1 to 7 of 7
Thread: 1uz coolant pipe where it go?
    Default 1uz coolant pipe where it go?
    Hi all, can anyone advise where this pipe should go? The one with the red circle around it.
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Default Re: 1uz coolant pipe where it go?
    NFI, its been capped off on every 1UZ I've had.
    Could it be for the recirculating overflow bottle, although the only ones I've seen come off the front of the engine?
    Had a look at my motor at home.
    On Celsior and UZS131 Crown motors its capped off.
    On Soarer motors it doesn't exist.
    Weird, mine had a pipe on it and in the front cut it appeared to run up into the windscreen wiper area. But whatever it went to had been removed.
    It was from a Celsior
    Ok so safe to cap it off
    thanks all
    My VVTi engine came out of a celsior - it didn't have the pipe where yours does, but it did have it in an intermediate pipe in the heater hose, although the tap off the intermediate pipe was blocked off...
    Maybe it's something for the rear heater?
    Joel, if your half cut has the recirculating overflow bottle connection at the front of the engine, then this one isn't it
    Mos.
    Celsior's don't have rear heaters, only rear aircon.
    I'll check my Celsior to see if its using it or not.
    The motor I have spare I presume is Celsior, but it could be a UZS141 Crown.
  1. Replies: 9
    Last Post: 12-04-2008, 06:59 PM
  2. Replies: 23
    Last Post: 29-04-2007, 01:18 PM
  3. 2JZGTE Engine Coolant Capacity? Aristo...or Supra
    By sbyder in forum Tech and Conversions
    Last Post: 08-03-2007, 08:08 PM
  4. 1jz-join between pump and coolant pipe
    By yann in forum Tech and Conversions
    Last Post: 30-08-2006, 02:57 PM
