Results 1 to 5 of 5
Thread: 20V 4AGE Cams/Valve Springs?
    Junior Member Domestic Engineer psychofox's Avatar
    Default 20V 4AGE Cams/Valve Springs?
    I've got a internally standard AE101 20V 4AGE in my AE86, and am looking modifying it.
    I have th following mods currently:
    - Microtech LT10s
    - 4-2-1 Extractors 2" system Hi flo cat
    - Custom plenum that bolts to the Quads w/K&N Pod Filter
    I want to extract some more NA power, but such that it's still streetable. I'm looking at around 272/264 degree cams for a bit more urge. I've already got a TRD 0.8mm MHG ready to go when for when I crack the head open
    Who apart from Toda or TRD make preformance cams for this head? Does anyone have cams in their 20V and can comment on gains / driveability?
    If I'm running cams of this duration (and corresponding increased lift) will it require heavier valve springs? If so again who makes them aside from Toda or TRD?
    Should I get the head cleaned up / ported at the same time?
    Thanks in advance Toymodders.
    Wollongong Sporting Car Club - Secretary
    Current Cars:
    2004 TW Magna VR-X AWD w/6G74 - Tow Car
    1989 AW11 MR2 w/4A-GE 20V - Track Car
    Fava beans and chianti Backyard Mechanic AE86slut's Avatar
    New South Wales
    Default Re: 20V 4AGE Cams/Valve Springs?
    Fletcher - I would give Toby at Meridian Motorsport in Victoria a cal onl (03) 9553 4200. He should be able to give you a couple of cheaper options as far as cams go, and also point you in the right direction with other ways of getting a bit more power.
    Jeremy.
    I am not a doctor, or a mechanic...
    A.K.A Otomoto
    All new - Fart!
    Quote Originally Posted by Vios-GT_07
    it was 10,000 kms b4 it saw the red-line.. but even then i seldom push it that hard unless i have to prove a point i.e. competition
    Junior Member Backyard Mechanic Dimitri's Avatar
    local manufacturer tighe do them.
    i dont think going to 272/264 will be worthwhile... the gains will be pretty minor and wont be good value for money... think about cams over 280 and dump the vvt for adjustable camgears...
    i agree
    it is all there. compression(especially with your metal HG), quads, ect. theyre a tough motor. get big cams.
    Last Post: 17-06-2008, 08:53 PM
  2. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
  3. 4age tech question?
    By pro-16t in forum Tech and Conversions
    Last Post: 30-04-2006, 10:42 PM
  4. 4AGE cooling system - an observation
    By roadsailing in forum Tech and Conversions
    Last Post: 18-12-2005, 11:01 AM
  5. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
