Results 1 to 9 of 9
Thread: 20v bottom end parts?need help
    Low rep Grease Monkey
    Default 20v bottom end parts?need help
    hi guys looking for for parts for the 20v bottom end build
    i am going to build it hi comp yes guys hi comp
    no turbo
    if anyone knows where i can get them cheap will be good
    what should i use and go for ?
    what piston?
    what rods?
    is the crank good in them?
    and others?
    need it to handle 80-100shot of nos
    Junior Member Grease Monkey GEMTA22's Avatar
    Sep 2008
    Default Re: 20v bottom end parts?need help
    What sort of budget you on ?
    How much power are you after ?
    Are you keen on sticking with nos
    Junior Member Backyard Mechanic KARNAGE's Avatar
    well the crank is the same item used in the 4agze so stick with that but once you have all the internals get a good balance performed on them trust me helps a lot. high comp pistons can be found in many places www.greenline.jp has quite a few set of pistons to suit the 20 valve and i think from memory they hold pistons up to 11.9:1 comp. conrods once again you could use the 4agze ones but they are heavy so look around for a good aftermarket forged item and make sure you use good bearings as well acl or the like
    Sep 2008
    ae101 4agze rods are the exact same rods as the 2v rods karnage, they are not heavy...
    ae92 4agze rods are the toughest 4agze rods, but that being said you would struggle to have problems with the ae101 rods
    The GOD HAND AW11 - sold
    it all comes down to budget.
    How fast do you want to spend?
    ...... butt scratcher?!
    i know that the ae101 rods are the same as the st20v i was just saying they were heavy compared to a aftermarket h beam style rod. and being a high comp he would wanted to have the lightest internals but still have good strength.
    well im looking for spending abt 3-4grand on parts
    any yes i will be putting it on the blottle
    well 3 to 4 grand will get you a fairly good bottem end but you will have to make sure that it is built well, clearances etc.
  1. 20v silvertop mild build. Stock Bottom End.
    By Brendan in forum Tech and Conversions
    Last Post: 31-07-2008, 05:49 PM
  2. 1G bottom end
    By Brian_J in forum Tech and Conversions
    Last Post: 28-06-2007, 04:56 PM
  3. 1UZ bottom end bits
    By mrshin in forum Tech and Conversions
    Last Post: 25-07-2006, 07:58 PM
