You cant. The main jet isnt adjustable from memory.
You can only set the idle speed and the idle jet.
 Carby Tuning 18rc
 Carby Tuning 18rc
				Hello Guys...
This isn't a really .... 100% answerable or mechanical question....
I have a 18rc.... i know i know... And i have looked around at many different sources... and they all seem to contradict.... anyway.... I have been told & know that my Lica' is running rich...... but How do i learn how to tune my carby? ... I have already had some experience with engines & carbys and have researched the mechanics.... but still i have no idea where to start?
I don't know if anyone could type out a step by step general guide?... with just general needle names.... (i have had a look at the thread on here about them but mine.... you guessed it... are different ....)
thanks in advance..
Dave
				 Re: Carby Tuning 18rc
Daily: Toyota '05 Rav4 Sport
				is it still the original carby, i think that its an aisin POS.
Getting your missus to help bleed the brakes isn't everybody's idea of quality time.
				Best you can do is go and buy a carby overhaul kit, make sure it is the one to suit your carby as there are a couple of types. strip the carby down and replace all the parts with the new ones that come in the kit.
The main reasons for it running rich are 1- high float level, 2- worn main jet,3-secondary throat opening too early.
The kit will come with a diagram and tell you the float level you need to set.
Cheers Dave
Cheers Dave
1977 RA28
1972 TA22
1984 Supra
				ook - thanks. Yeh secondry isn't even working lol ... Float is about ... 2mil from the top... does look a bit high really,,,,,
Ill have a look around.
Thanks
Dave
				Yep.... that be the one....Originally Posted by maurice c
my friend has a weber hes not using..... *Shifty Eyes*
				replace it with a 2bbl webber from a TC or similar 2 litre Cortina - try to do this cheaply or for no money as spending money on an 18RC is a pointless exercise.
				Not true.Originally Posted by thechuckster
I installed a Webber 34ADM on my 18R-C. It brought new life to the engine.
For ~$50, it was the best $$s i ever spent on the car.
				how did u test this theory?Originally Posted by toylica
thx
Bat mobil + 4age.. Engine painted, Fitting up now. Not long...Originally Posted by roadkill
Live life on the edge.
				well.... i guess you know something i dont.Originally Posted by Cob604
the throat isn't wet.....someone said that the diaphragm dies.....?
thnx
				wow... are they that cheap? where from? or just.... snipe one on ebay?Originally Posted by MWP
thnx
dave
				hey
i had mine die a few weeks ago, the diaphragm opens it therefor u wont see it open if u push the throttle, it only opens under load. so i put a new one on & just cruising down a road if u push ur foot to the floor at a point the intake noise gets deeper & madder
with car off when i opened the secondaries by hand i could hear the air coming out of the diaphragm
just from memory
thx
				It was from a u-pull-it off a Falcon XE/XF.
The 34ADM isnt the ideal carb (it is too large) so it took a decent amount of work to get it tuned properly.
Yup, they do.Originally Posted by toylica
I fixed this on my original 18R carb which made a huge difference.
I fixed it by using a simple wire link to make the second butterfly open after ~75% throttle (bypassing the diaphragm).
Its still worth looking at a Weber carb anyway, the 34ADM made a big difference even after the original carb fix.
				Interesting.... so if i wanted to test the diaphragm.... how would i go about it.... and... is it just the diaphragm that is nearest the front of the car...?Originally Posted by MWP
When i got flat to the floor i do hear the deeper sound and such (especially with the modded intake)
thanks
dave
				You cant test it without pulling it apart.
Its diaphragm actuated to stop it from opening at too low a RPM which could then stall the engine.
If your hearing that deep sound throughout the rev range at full accel, then thats not it.
If it is working, you should hear the note change or get louder at some point through the rev range.
