CAS leaking oil?
Hey guys,
Recently my car has been not starting, like ill be idling and it will just stop or i turn it off and it won't start again, car has a 1G with Microtech LTX12, now the microtech is showing no errors, its getting fuel, all the fuses are good, its got good cranking amps so not alternator, any other ideas?, leave it for a few minutes and it fires again?
Cheers guys
1977 Toyota Corolla KE30 1GGTE http://www.toymods.net/forums/showth...post7372821977
1987 Ford Falcon XF S Pac
1ggtes have a dizzy arangement, unless hes replaced it with the 1ggze cas unit.
RA23 - Twincharged
JZZ20 - Daily
when its doing its "wont start thing" do you get spark?
RA23 - Twincharged
JZZ20 - Daily
It doesn't run a dizzy, the microtech manages the spark and ignition with a cas. and single coil packs.
Not sure i will check that next time it happens, its happened about 5-6 times, also its got a 910 bosch pump and recently when i turn my blinkers on it sort of sounds like the voltage to the pump is low and mimics the blinking sound?? only started noticing this recently,
thanks kedderz n adam![]()
well i looked at the voltage readout on the hand controller driving normally around 14.5v, cranking about 10-11?
sound right?
Yeah battery in boot, all earths in boot look good, got a earth grounding thingy in the engine bay with all the earths on that, I'll have to have a chat to Josh about it tonight.
Cheers Adam
Heya trentus.
If its cranking strong it wont be bad battery or terminals.....
Could the fuel pump possibly be shagged/dicky? Perhaps its unable to supply enough fuel pressure for the injectors when it plays up (when it mimics voltage drop from blinkers). But, comes good again when it cools down or watever
I have a secondhand 044 and a VL turbo fuel pump we can throw in it for a bit to see if its the problem![]()
Yeah Trent, can you clarify, is it cranking but not firing??
What's your fuel pressure reading when this trouble happens?
Do you happen to have a Malpassi fuel reg?
My KE25 thread
Yeah its not temp related though bro, cause sometimes it does it when its operating temp or stone cold?
Could be bad earths im guessing..
Xx
Cranking strong as, jus using stock regulator.
Chuck a fuel pressure gauge on (they are cheap less than $40 for a turbosmart one, less than $20 for a speco) and rule out a fuel pressure issue due to what ever reason.Originally Posted by Trent-KE30
Might save you chasing unknown faults.
My KE25 thread
