Results 1 to 4 of 4
Thread: Help required : RA-40 struts into a KE30 ??
    Default Help required : RA-40 struts into a KE30 ??
    Hello all, I am doing an upgrade into my KE30.
    I was wondering if anyone has done this conversion, and how easy / hard is it to do?
    Is it true I can use the KE30 strut top hats on the RA 40 struts?
    Can the RA 40 steering arm / strut bottom bolt onto the KE30 LCA?
    I am also wanting to lower the car substantually.
    I know that I can use Camry 83-86 front shocks in the RA-40 struts which will be suitable for a 3 inch drop, and still retain a fully functioning shock that won't bottom out.
    1975 KE30 Two Door - 3K BP, K50, & BW4.3
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    Default Re: Help required : RA-40 struts into a KE30 ??
    strut conversion = easy brake upgrade but also can affect steering / front end geometry.
    lowering a street car substantially will make it scrape and bottom out substantially.
    look into xt130 struts though and maybe low springs instead of superlows to keep that
    exhaust where it is meant to be
    My Missus is a Domestic Engineer BradW's Avatar
    I have bolted an RA40 strut into my KE30 for a test fit, but haven't driven the car with them yet.
    Yes, the KE30 top hats will bolt straight onto the RA40 strut.
    Not sure on this, I used RA40 lca's which were the same length as the KE30 items and bolted straight in. The reason I am using the RA40 struts over something like XT 130 is because my budget is pretty tight and I got the RA40 struts for free .
    As for springs, I plan to swap the KE30 lower spring platform onto the RA40 strut. This way I can use KE30 springs ( I don't plan to lower the car too much, maybe 1- 2" ).
    Check the diameter of the camry springs. If they are the same as the RA40 then they will most likely foul on the strut tower.
    Click on the link in my sig to see pics of my test fit.
    Brad
    Old Corollas never die...
    My KE30
    Cheers for the help so far peoples.
    Dale J.
  1. ST162 - Installing Series 1 rear struts into a Series 2
    By RobST162 in forum Tech and Conversions
    Last Post: 26-10-2006, 11:51 AM
  2. KE30 Front Struts!
    By Trent-KE30 in forum Tech and Conversions
    Last Post: 20-05-2006, 05:35 PM
  3. RA60 Front struts on KE30
    By 78Rolla in forum Tech and Conversions
    Last Post: 29-03-2006, 10:28 PM
