Results 1 to 15 of 16
Thread: Sourcing small metal gears
    Default Sourcing small metal gears
    Hey guys, I am looking for some some gears which are roughly 5 to 10mm wide and 20 to 50mm diamater. I want these to be made to steel to handle a decent amount of torque and have straight cut teeth. I am looking to make my own 2 speed gearbox with dog engagement for a 40cc 2 stroke engine. I will given the choice have an under-drive/over-drive combination with a manual gear change using a spring to hold it in gear.
    Does anyone know of any device thats available that I can take apart that has some metal gears like inside? I only need the gears, I will make the shaft and the dogs myself.
    -sam
    Default Re: Sourcing small metal gears
    There are actual places that only sell gears. Either buy some from there or have a gear cutting place make you some.
    Try the gears from a reduction starter.
    (again! )
    www.billzilla.org
    Toymods founding member #3
    Lathe thread cutting gears might be what you are after...
    ok thanks guys, I will have a look at a 5sfe reduction starter, there where a few of them at the wrecker
    Other than that I was thinking maybe a washing machine gearbox would have something
    Quote Originally Posted by Ben Wilson
    Prease be expraining this to me
    Unless machining a worm gear, how can a lathe be used?
    I thought he meant the change gears for the thread curtting auto feed. These are the gears that move the spindle to adjust the motion of the cuttering tip to cut the thread.
    But hey I may be thinking of something else tottaly
    Quote Originally Posted by Sam_Q
    Yes a moment of blatant stupidity from yours truly, especially when I'm a fitter and machinist.........
    why not bike gearboxes?
    way too heavy, I want the whole box when finished to be about 1kg
    i mean take the gears from inside the bike gearbox... thye are small, you could machine them thinner, and you know they will be strong enough.
    or, use chain and sprockets....
    some electric drills have 2 speed gerboxes
    Jealousy is a curse
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    in pitbike motors the:
    lifan
    ducar
    yx
    have gear sets approx 20 to 50mm in diameter,
    and im not sure maybe 20mm wide?
    all handle 140cc 4 stroke power of 8 to 12hp.
    hobby stores might be too small but heres one:
    http://www.smallparts.com.au/catalogue/individual/
    madmont: funny enough I stripped the gearbox of my drill on the day you made that post and thy arnt made very strong.
    styler: that probably would of been my next port of call but I think if I go down this road I am going to just use chains and sprockets like what corollas is suggesting. This is a good option because I can drill my own sprockets and then I can make them have integral dogs for a nice light and compact design, I will see
    so thanks for the help guys
    Jun 2006
    hey i have a lifan pitbike gearbox apart here and it has
    10mm wide gears, ranging in diameter from 20 to 50mm or so...
    straight cut too they also use a conventional dog gear design
    i can do pics with a tape for mm measurements if you want?
  1. 4AGE small port --> making the ports smaller again
    By 92-GTI in forum Tech and Conversions
    Last Post: 09-03-2006, 02:51 PM
