bump it.. bump it reall good.
Hey guys, i recently replaced the 3SFE POS in my car with the much nicer 3S-GE (as well as installing all the other optional extrasand basically i've encountered my first problem.. my fuel guage reads as low as the guage goes, and my fuel light is constantly on (even though i had 1/2 tank of fuel already, and i have since put another 10 litres in... i'm fairly sure this is a wiring issue, however i'd like to check.. does anyone know how the fuel sender works? there are 4 wires...
yellow red stripe
yellow green stripe
white black stripe
brown
i'd appreciate it if anyone knows what they do![]()
your best to post this in the st162 dedicated thread
http://www.toymods.net/forums/showth...2504#post72504
you'll get a fater response there
[CENTER]Only God Can Judge Me
Current Ride(s):
1990 ADM Toyota MR2 with Jap Spec 3sgte transplant
thanks dude, good point
I had this exact same problem after i finished my 3sgte swap into my 162, did you cange the wiring loom behind the dash at all?
what mine turned out to be was a simple case of mismatching wiring, when i replaced the cars wiring loom (engine bay, front, behind dash) and joined it to the rest of the car, the 165 GT4 loom got sligthly differant signals from the level indicator. On my 162 i had never seen the fuel light until i did this swap when the guage read nill and the light was on.
I swapped the 2 signal wires from the level sender (the yellow with red strip and the yellow with green stripe), this then gave the dash correct readings, the light is back to normal (never on) and the fuel guage worked fine. I can't remember how i figured it out, but i remember i put alot of effort into it
maybe the fe loom is like the gt4 loom, while the ge loom is differant.
89' MR2 AW11... His
00' MR2 ZZW30... Hers
