Well done that looks awesome
How much boost are you planning on cranking it up to.
Looks like a very clean install
So I have basically finished the conversion, still have a rear subframe that needs new bushes and are changing the clutch setup (hence the low boost tune...)
A very rough break down of the conversion parts from NA auto to manual Turbo below and yes some are just the show bits or maintenance, but a complete list of whats gone into it so far:
Twin turbosmart 38mm wastegates
HKS TA45S Turbo
Tial BOV
Work Emotion XD9 18" wheels and Work nuts
Custom catch can and breather K&N filter
Active spoiler installation
4 pot front calipers and TRD pads with SS brake lines
Bride seat rails
Recaro SR3 seats (from Honda Type R)
Late model indicators and brake lights
Custom front grill
TRD speedo
Momo steering wheel
Momo boss kit
R154 gearbox
Clutch (QM Twin plate)
Custom Flywheel
Pedal box
Slave / master cylinder $200 $30*
Shift knob (TRD)
Shift boot
R154 to 1UZ / Bell housing
QM Hydro Release bearing
Rev counter
1UZFE engine
Engine mounts
Link Plus G3 computer
Misc hoses / lines / clamps etc
Engine Start S2000 switch
Maintenance parts etc
Batteries (Vertex dry cell)
Electric fans (2 x 10")
Loom & temp sensor & ignitor
Release bearing spacer
Gearbox mounts
Modified drive shaft
Move shifter lever position
Heater hoses and PS lines
Exhaust
Battery and Alternator cabling and brackets
Fuel, clutch, and turbo feed and drain lines
Fluids
Intake pipe & K&N filter
Dyno Tuning (331 at 5psi)
Injectors (EVO 510cc)
Intake and throttle body modification
RB idle valve
Carbon hood shocks
TRD oil cap
In the garage to go and on finish
ARP head studs
Performance valve springs
Cometic head gasket
Big valve and ported head (in development)
Sorry for the crappy pics, but here is a turbo 1UZ SupraIt made 331WHP at 5psi.
More pics Andrew. Bay looks tidy but i want to see those X9's
Had it to an autocross with the turbo yet?
looks awesome mate, and decent power on only 5psi!
87' z20 Soarer - 1jz Gt35r -
Thanks mate, will run 10psi on 98 BP pump gas. hoping for 410-420WHP on 10psi.Originally Posted by 2jzhilux
When the heads go on, looking for 18psi on pump gas still and around 550WHP. Will see... thats a few months away yet.
Will get more pics soon, car is in getting a warrant of fitness.Originally Posted by JustenGT8
Not been on the track as I am changing clutches.
On that, do you like the Tilton I sold you? I am going to move to a single disk Exedy or similar, do you think the hydraulic release mechanism will or with a 9.5" cover? if the right bearing was made to fit on the sleeve that goes into the release mechanism?
Looks very good, almost factory.
www.billzilla.org
Toymods founding member #3
The Tilton is great for track, pretty shit for street.....not so much the harsh takeup, more that every street launch is doing serious wear and the thin clutch plates don't have much life in them. If a box drop is pretty easy then maybe OK?Originally Posted by 4000GT
My next clutch will be a quad plate organic 7.25 from the UK rated for 900hp and stock feel.
Thanks Bill...
Justen, yeah ok I dont have the love for multiplate setups, though people rave about these $4,000 carbon setups. What would you recommend for a single disk 9.5" capable of 5-600ftlbs? Thought on using the floating hydraulic release on a 9.5"?
Dunno mate....can't say i believe a single plate could handle that torque? not for long anyways?
Having seen a carbon triple plate on a 400+rwkw Supra i know why they are raved about.....very impressive. That's alot to pay for a clutch though.
Yeah maybe I keep this going for a while and grab a carbon clutch down the track.
Nice choice of wheels, my XD9's were fitted on Saturday![]()
verry sexxy
Subscribed, looks beatiful man! Very clean indeed, almost looks factoryBar the f*ck off big turbo
CHeers,
Jase
Impressive. Have you got any pictures of the exhaust manifold?
"Don't worry what people think, they don't do it very often."Originally Posted by oldcorollas
