if it flows too fast, the radiator doesn't work efficiently and you make things worse ... at least that's my take on it.
Assuming the radiator has been flushed, the fins are OK and all the cores open, I'd suggest you look at ducting to the front of the car to:
-get more air flowing into the void from front bar to radiators
-make that void slow the air speed down
-seal that void up so air cannot flow out the sides or underneath
-make sure you have some kind of undertray so hot air existing the radiator(s) can flow thru the engine bay rather than meet a high pressure and turbulent zone courtesy of no undertray
You'll get better heat transfer if the air flowing thru the radiator(s) is slowed.
What temp is the bottom hose from the radiator?
