Results 16 to 28 of 28
Thread: 1ggte build up
    The old One Backyard Mechanic
    Default Re: 1ggte build up
    Gidday Stefan
    I have a Garrett GT25 Part number 705330-001, CHRA part number 446179-0018.
    Compressor stage
    Hsg A/R 0.70, Wheel Trim 48 Model TI4S Wheel diameter 2.09/3.00 Horse power 400, Compressor Flow 44 (lbs)
    Turbine stage
    Hsg A/R 0.64 Wheel trim 76, Wheel diameter 1.85/2.12.
    Main reason for upgrade is that I believe that the compressor will run out of puff with the revs available in the new motor, I would like more power and the extra capacity of the engine should help spool up.
    Craig
    TAS
    If that is similar to a stock S13/14/15 turbo, then I understand.
    TAS
    Quote Originally Posted by Stefan
    I'd appreciate input from Kyle or Linden here, someone with experience. While I understand what the dude is saying, he makes no mention of how this relates to the 6 having 1.5 times the pulses.
    TAS
    True that, but I have heard this advice from elsewhere also.
    Stefan
    Get real. Where did a stock s13/14/15 turbo get rated at 400 hp @ 1.2 bar. Hope the rest of you comments have more credibility.
    Craig
    TAS
    I didn't read your post properly that time, for some reason I was thinking T25 when I read GT25.
    As for housings - how expensive is the .82? You could always try it and swap back...
    Housings are about $800 plus fitting - which is amazing for a $1800 Turbo. Queanbeyan diesel think they have a .82 that they swapped out. They are looking in the store room for it.
    Craig
    are you coming to marquees in the park craig? its an ACT event this sunday
    RA23 - Twincharged
    JZZ20 - Daily
    Not with the car - I have not registered it since returning from PNG. I will take some photos of oil and water connections and post them in your other thread.
    Craig
    Thanks mate that would be fantastic. You should get a permit for the car and enter it, thats what im doing with the starlet.
    RA23 - Twincharged
    JZZ20 - Daily
    TAS
    Do my oil & water line photos have credibility? /ducks
    they do show the basic premise of how to do it yes ;-)
    RA23 - Twincharged
    JZZ20 - Daily
  1. RA65 22RE Bellhousing vs 1GGTE
    Last Post: 18-08-2006, 04:58 PM
