If that is similar to a stock S13/14/15 turbo, then I understand.
Gidday Stefan
I have a Garrett GT25 Part number 705330-001, CHRA part number 446179-0018.
Compressor stage
Hsg A/R 0.70, Wheel Trim 48 Model TI4S Wheel diameter 2.09/3.00 Horse power 400, Compressor Flow 44 (lbs)
Turbine stage
Hsg A/R 0.64 Wheel trim 76, Wheel diameter 1.85/2.12.
Main reason for upgrade is that I believe that the compressor will run out of puff with the revs available in the new motor, I would like more power and the extra capacity of the engine should help spool up.
Craig
I'd appreciate input from Kyle or Linden here, someone with experience. While I understand what the dude is saying, he makes no mention of how this relates to the 6 having 1.5 times the pulses.Originally Posted by Stefan
True that, but I have heard this advice from elsewhere also.
Stefan
Get real. Where did a stock s13/14/15 turbo get rated at 400 hp @ 1.2 bar. Hope the rest of you comments have more credibility.
Craig
I didn't read your post properly that time, for some reason I was thinking T25 when I read GT25.
As for housings - how expensive is the .82? You could always try it and swap back...
Housings are about $800 plus fitting - which is amazing for a $1800 Turbo. Queanbeyan diesel think they have a .82 that they swapped out. They are looking in the store room for it.
Craig
are you coming to marquees in the park craig? its an ACT event this sunday
RA23 - Twincharged
JZZ20 - Daily
Not with the car - I have not registered it since returning from PNG. I will take some photos of oil and water connections and post them in your other thread.
Craig
Thanks mate that would be fantastic. You should get a permit for the car and enter it, thats what im doing with the starlet.
RA23 - Twincharged
JZZ20 - Daily
Do my oil & water line photos have credibility?/ducks
they do show the basic premise of how to do it yes ;-)
RA23 - Twincharged
JZZ20 - Daily
