Advises of low fluid level via (most probably) a light on the dash or digital display.
Quoted from the Toyota Oddities Interchangability thread!Originally Posted by Negative Boost
What is this electronic sender do?? i was going over my engine bay yesterday and found the wires for this sender arent attached, they have broken off, what does this sender do, how does it affect the brakes, i have used the search but with no results.
thanxs
wog
oh is that all? i thought it had an actual mechanical function!
thanxs
The little float just completes the circuit when you get low on fluid. Low brake fluid is something you need to know about sooner rather than later.
Getting your missus to help bleed the brakes isn't everybody's idea of quality time.
^^^ yea true, but somebody like me is always checking fluid levels and making sure everything is ok, but then again, not everyone is like me!
Its not actually there just to tell you the fluid is low.
Most manufacturers have them setup so once the BRAKE light comes on it means your pads are nearly screwed and thus require replacement.
But it wont work if like most ppl you just top the fluid up all the time, so by the time you have figured out the pads need changing they have normally gone metal on metal and practicaly rooted your rotors.
linden
Originally Posted by WHITCHY
^^^ i got no problem of that happenning, i pulled off rims and inspected and bled all the brakes, plenty of meat.
thanxs guys
wog
