Results 1 to 7 of 7
Thread: Brake reservoir electronic sender?
    Mar 2008
    inner west syd now!
    Default Brake reservoir electronic sender?
    MA61 bore is 15/16in $300
    Landrcuiser is 7/8in $90
    Everything else is the same bar the cap on the reservoir which doesn't have an electronic sender on it so you have to use the MA61 cap.
    Quoted from the Toyota Oddities Interchangability thread!
    What is this electronic sender do?? i was going over my engine bay yesterday and found the wires for this sender arent attached, they have broken off, what does this sender do, how does it affect the brakes, i have used the search but with no results.
    thanxs
    wog
    Default Re: Brake reservoir electronic sender?
    Advises of low fluid level via (most probably) a light on the dash or digital display.
    Mar 2008
    inner west syd now!
    oh is that all? i thought it had an actual mechanical function!
    thanxs
    Junior Member Backyard Mechanic maurice c's Avatar
    Yes we Canberra
    The little float just completes the circuit when you get low on fluid. Low brake fluid is something you need to know about sooner rather than later.
    Getting your missus to help bleed the brakes isn't everybody's idea of quality time.
    Mar 2008
    inner west syd now!
    ^^^ yea true, but somebody like me is always checking fluid levels and making sure everything is ok, but then again, not everyone is like me!
    Forum Sponsor Conversion King
    Its not actually there just to tell you the fluid is low.
    Most manufacturers have them setup so once the BRAKE light comes on it means your pads are nearly screwed and thus require replacement.
    But it wont work if like most ppl you just top the fluid up all the time, so by the time you have figured out the pads need changing they have normally gone metal on metal and practicaly rooted your rotors.
    linden
    Mar 2008
    inner west syd now!
    ^^^ i got no problem of that happenning, i pulled off rims and inspected and bled all the brakes, plenty of meat.
    thanxs guys
    wog
    By The Witzl in forum FAQ
  2. Replies: 12
    Last Post: 01-02-2007, 11:04 AM
