Results 1 to 12 of 12
Thread: ABS problem
    Sep 2008
    Default ABS problem
    Hi all
    Just tonight the ABS warning light in my 2004 stock hilux came on so i tested it (slammed on brakes when no-one was around) and yep the ABS isnt there anymore.
    As i'm not sure how exactly the ABS interacts with the brakes i was wondering if anyone new if this might stop my brakes from working further down the line or if i am safe for the time being.
    Also, if anyone might know what could be causing it i'd be much appreciated. I know that this isn't much information to go on but if it is a semi-common problem that might be occuring i'd thank you forever if you could tell me.
    Thanks
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Default Re: ABS problem
    Only way to tell is by using scanner/Toyota Intelligent Tester. Brakes will still work fine if they feel fine now. May be something like one of the wheel speed sensors.
    if the abs computer has sensed a fault somewhere the ABS system will be disabled but the brakes will contune to work normally (bar the abs)
    most common faults for ABS are dirty speed sensors, if these disagree with vehicle speed, abs ecu will throw a fault and abs will turn off.
    this fault should reset itself once ingintion is turned off, and re-appear while braking at low speeds. you might feel the ABS kicking in when it shouldnt before the system disables itself.
    Adelaide, SA
    More than one code for speed sensors. There are open circuit codes for each one, and improper operation ones. Compares between other wheels and main speed signal. Take it to a Toyota dealer and get them to pull the code with the IT2.
    I've done 3 ABS jobs in the last week:
    1. Broken cable to RHR speed sensor. (Code logged, open circuit)
    2. Faulty LHR speed sensor. (Code logged, faulty operation)
    3. Faulty ABS actuator assembly (No code logged)
    Be thankful you have a code logged, cos it means it shouldn't be the actuator assembly. New one of those for the Rav4 I was working on was $3500.
    vic
    Hey Gav , do you work at a toyota dealer?
    Are you getting many of the accumulator masters like on the cruisers/prado,s packing it in?
    Dave
    Adelaide, SA
    Yeah
    I've replaced one in the last 3 years. And that had black as all fuck brake fluid in it. So no, not really.
    vic
    Yeah same ive seen 2 fail but heard of many more , Dot 4 fluid kills the rubbers in them .
    Dave
    Yep, DOT4 killed the master cyl in dads Prado (1998, non-ABS).
    Rebuilt the MC and used DOT3 and it was fine.
    doesnt toyota recomend dot 3 only anyway?.....i cant remember if its toyota or some other brand?
    nucking futs double post!
    Adelaide, SA
    Genuine Toyota fluid is DOT 3.
    Probably, but most people would think that DOT4 has replaced DOT3 (much like Dex3 replaced Dex2), so they'll just buy it.
  1. A340e Sluggish takeoff? Lockup Solenoid Problem?
    By Z2TT in forum Tech and Conversions
    Last Post: 13-01-2012, 05:10 PM
  2. 7mgte ideling problem and pressure problem
    By HAIRY_APES_22'S in forum Tech and Conversions
    Last Post: 25-05-2008, 05:43 PM
  3. AE82 - Electric Problem
    By convert in forum Tech and Conversions
    Last Post: 24-02-2008, 11:30 PM
  4. Toymods Uploaded photos problem
    By JBs in forum Toymods Car Club Membership and Feedback
    Last Post: 26-11-2007, 03:18 AM
  5. CV joints problem with bigger engine (FWD)
    By progkamol in forum Tech and Conversions
    Last Post: 15-08-2006, 02:00 PM
