Results 1 to 4 of 4
Thread: f series diff filler bolt specs
    Default f series diff filler bolt specs
    howdy,
    filler bolt is rounded off on my F series LSD does anyone know the specs (length thread pitch etc) or a part number so i can get a new one and get a mechanic to take the old one off?
    nathan
    Default Re: f series diff filler bolt specs
    Assuming MA61 IRS?
    M18x1.5, ~10mm thread Depth (with copper washer installed), 27mm Socket to remove.
    Why not get a new one (and copper washer) from Toyota and weld a decent nut on it while it is out before install?
    I'm not sure what the difference between the part numbers / years but I suspect they interchangeable... I think maybe one has a flat head and the one has a slightly recessed head (I recall seeing two different types in my life?!)
    Toyota: 90341-18049 [8108-8401], AA63, SA63, RA61, 63, MA61, Plug for rear differential carrier cover
    Toyota: 90341-18006 [8401-8512], AA63, SA63, RA6#, MA61, Plug for rear differential carrier cover
    Toyota: 12157-10010 [8108-8512], AA63, SA63, RA61, 63, MA61, Gasket for rear differential carrier cover
    Wilbo's JZA80
    Wilbo's JZZ12
    its is indeed irs
    hmmmm mine is 24mm socket, other specs should be the same i guess
    the parts you listed there are two for the same thing?
    thanks for your reply man
    doubeld post
  1. Installing LSD Into G Series Live Diff
    Last Post: 18-06-2008, 02:13 AM
  2. F Series Diff - MA61 pinion housing to MX23?
    By Screamn_Sleeka in forum Tech and Conversions
    Last Post: 14-03-2007, 12:54 PM
  3. Mythbusters - S and T series diff strength
    By Hen in forum Tech and Conversions
    Last Post: 28-06-2006, 07:12 PM
