Results 1 to 4 of 4
Thread: removing steel pipe from cast alloy waterpump housing
    Default removing steel pipe from cast alloy waterpump housing
    Hi all
    I am converting a 20v to rwd in my ke70. I need to modify the water bypass pipe. I.e. take the interference straight steel pipe out and put a bent one in.
    whats the best way to do this? break out the oxy? or chuck it in boiling water?
    Daniel
    Past - 3 RA23's 1 TA22 - Hairdresser mobiles
    Present - Red 4age KE70 - Sideways shopping trolly
    Future - White KE70 - Grandma shopping trolly
    Default Re: removing steel pipe from cast alloy waterpump housing
    Be very careful if you use the oxy as I did this on a different water housing and while it worked for 3 of the pipes it is very easy to melt the alloy as it doesn't get red and give you warning. I melted it on the 4th pipe I was getting out.
    Still worth giving it a try
    Or if you dont need the pipe then hacksaw or die grind it from the inside then fold it in on itself and out it will come.
    Junior Member Grease Monkey rick q's Avatar
    Why not just leave the straight piece in place, and add the bend to it using a short piece of radiator hose - that's how I did mine - though it won't work if you're leaving the standard curved cast pipe from the cylinder head in place
    Cheers ..... Rick Jones
    Fraser Clubman
  1. Sam-Q's 20V RWD Cooling System Guide
    By Sam_Q in forum Engine & Driveline Conversions
    Last Post: 27-03-2007, 05:08 AM
