Results 1 to 15 of 20
Thread: 3S beams to AE86 conversion
    Junior Member Grease Monkey cressida_1jz's Avatar
    Default 3S beams to AE86 conversion
    Hey im helping a mate do a 3S Altezza motor to AE86 conversion and looking around for some info or if anyone else has done it here before.
    Basic things like engine mounts,gearbox mounts (6 speed) and sump.
    Were looking at a dry sump setup or whatever is easier and will work.
    Any info or direction of were to look will be much appreciated.
    Cheers,mark
    1997 JZX100 Chaser Tourer V
    1991 Cressida Grande 1JZ-GTE *sold*
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    Default Re: 3S beams to AE86 conversion
    www.billzilla.org
    Toymods founding member #3
    Jan 2010
    beams in corollas yeeeeeeeeees.
    hoping to put one in my ke55
    Perth WA
    Keep the factory Altezza alloy mounts. I used Holden V8 Adventura rubber mounts and made my own pedastal to sit them on, once I'd removed the factory steel mount from the engine crossmember. If you keep the wet sump, remove the webbing along the back to sit the engine lower, and pay some attention to the final height - you may need to space the crossmember down to clear the bonnet. Fab up a gearbox mount to suit, and you're part way there!
    Thanks for the info,mounting and sump was our main concern but all this helps.Were also trying to make a R154 fit if we can because the motor it getting turbocharged and should be making decent amount of power.
    We already have a 3SGTE block fully built forgies,rods ect but not sure if they would be the same block because of the VVT-i and thought using an Altezza front cut may make it easier.So we may have to build the Beams motor to suit the turbo.
    Perth WA
    The blocks are the same, but different! Use the BEAMS block - it will have more mounting options.
    Yeah thats what i thought.We can use the internalls out of the GTE for the Beams.
    iconoclast Backyard Mechanic Youngy's Avatar
    dry sump it!
    this sounds serious
    Yeah dry sump is the option because of the power my mate wants to get out of it.Its getting built for drift.
    May 2006
    tas
    sounds like a lot of effort for a drift bus. SR would have done the job
    buddy parts in SA was working on conversion mounts for 3s (spcifically beams) > ae86
    also maybe take a look at the beau yates (TRD) old bus, that had a turbo beams.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Jan 2007
    queensland
    sit the motor and box in there and take it to a good fabrication shop.. ?
    Apr 2009
    California
    1st gen 3SGE blocks have an easy option for engine mounts and can get from toyota new I believe, 1S or 2S RWD Engine mounts from corona out there I believe?? Oil pan from that will help with upright positioning. Beams has a two piece oil pan, but remember oil drains on 3SGTE are only on one side of the block, oil will pool in the head, I did this swap in an 86 and hap oil starvation while drifting (burnt two motors). If you use Hilux(Tacoma out here) 5VZ Manual bellhousing, that will bolt the 3S to the R sereies box I believe, please correct me if im wrong, but VZ and MZ motors use same bellhousing, same a 5S and 3S pattern ask the SW20 guys.
    1983 KP61 - High Comp 4AGE, Celica-Supra Rear, etc.
    1971 Volswagen Baja Bug - 1835cc, Megasquirt, Type 2 Trans
    1997 KZN185 - 3RZ W59, Tundra Front Coils, ELocker
    Nov 2010
    tasmania
    2s mounts do not work that great with beams in an 86 environment, it sits the engine very forward.
    i believe elsewhere the vz bell was shown to work with the r box, but needs a spacer to compensate for the input shaft length.
    3y bell and w box is easy enough.
    custom mounts on crossmember seemed the easiest to me.
    Last Post: 17-06-2008, 08:53 PM
  2. AE86 Gearbox Conversion Options
    By Garth AE86 in forum Tech and Conversions
    Last Post: 20-03-2006, 01:30 AM
