Here we can see that all the gauges are self-contained. They can be removed induvidually and even relocated to another slot with a bit of fiddling with the rear PCB and some wiring. This also means that for those performing 4A-GZE conversions that the GZE tacho can be put in place of the GE (but tach signals will be different and therefore need to be accounted for).
ILLUMINATION:
Below each gauge sits the screw layout for mounting into the cluster body. Note the globes/bulbs are orignally 3W globes with a light blue silicon sleeve. These can be replaced with 5W globes for a more vibrant display. It is also worth noting that the Narva blue silicon sleeves are not a suitable replacement for these light blue sleeves as they filter more blue light and allow more yellow light to pass resulting in a greenish colour.
Any colour LED or globe sleeve other than blue will result in a slightly dimmer display. This is because printed on the backing of each gauge face is a blue layer which further filters the yellow wavelengths to make the numbers on the gauge look more white. The gauge needles do NOT have this blue layer and so you can notice that the needles appear more yellowish than the numbers on the gauge face at night.
A comment on LED replacement bulbs. We can see that there are 6 gauges (ignoring the clock) and only 4 bulbs. It's designed so that there is a clear plastic array underneath all the gauges which disperses the light via Internal Relflection. This means that when an LED is installed a bright circle will appear rather than evenly dispersed light. To overcome this it is highly recommended to use convex lens (a.k.a Inverted Cone) LEDs.
