As it has coil and lower wishbone in front, you can't 'reweld' the perch.Originally Posted by RiceburnaGTV
Cheap way would be cut a bit off the spring
As for the rear...lowering blocks...or, you can 'flatten' out the leaves a bit by dismantling the spring and doing each leaf separately.
I have done this often to 'raise' leaf springs, so I can't see why it won't work the other way.
I can explain the method if you are interested.
			 Lowering an RT81 what shocks and springs?
