as RAd mentioned to me, the 18RG is shim under... so any increase in shim thickness is just lifting the bucket out of it's bore... how much is too much?
when you increase lift, at least of a K motor, then you have think about 2 main things...Originally Posted by timbosaurus
first is how much lower the lifter sits in the bore, especially if you have machined the walls thinner, cos having too much will start putting undue stress and friction every time ti lifts (cos too much is pokin ou the hole)
second, you realyl should machine down the rocker towers by the same amount as the increase in lift, otherwise you bugger up the wipe of the rocker on the valve, and get large wipe with large force = baaad. more wipe near lowest load is much better.
of course you can not do that, but then your rockers and valves wear out faster and they need to be adjustmed more often and they are noisier (as they try and grind themselves to death)
but that is not so relevant here![]()
. Only because it increases the chance of the shim popping out, and we dont want that to happen!
