Results 16 to 30 of 43
Thread: 2JZGTE + Microtech + Stock turbos
    Default Re: 2JZGTE + Microtech + Stock turbos
    no the wastegate on the no1 turbro, bro.
    ill come over on saturday and show u how to do it
    sweet es brew
    ill be kickin around friday night if you wanna come then instead
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    WTF?!? Wastegzate permanantly open?? Why?
    You're a retard, and so are you Matt, hook up the w'gate as usual, wire open the 2nd turbo exhaust control valve & run a dump off the standard y pipe. Then remove and blank any actuators, valves, vac ports etc.
    Wastegate always open will make the WTEs (worst turbos evah!) even laggier.
    SHUT UP DICKHEAD YOU HAVE UNDER 5000 REP POINTS AND A 1JZ SO WHAT WOULD YOU KNOW
    lol
    im actually laughing
    Quote Originally Posted by BigWorm
    WTF?!?
    Wire open the 2nd turbo exhaust control valve
    No need to wire the rear turbo prespool valve open... Just remove the ceramic flap bit
    He's right about the wastegate tho
    Wilbo's JZA80
    Wilbo's JZZ12
    Yeah but that would take 20 mins rather than 5, plus it will help restrict up the zorst.
    Shit matt, I thought you would have learnt by now. Although I guess you didn't figure it out after the first ECU....
    lurker 1st year Apprentice
    unit 2 fredrick st
    just make a new dump with no waste gates in it... the connect a pop off valve to your exhaust.. its simular to a blow off valve but its for your exhaust system.. they are commonly used on turbo cars from the 1920's.
    do you guys know anything about remapping the standard computer on my 1jz or my 2jz i herd some guy from here was getting involved with this and buying up all the ecus to do some testing ?
    We must have communication issues
    Big Ceramic Flap = EGBV (Exhuast Gas Bypass Valve) --> Remove, it comes off easy and just make dumps to go from there
    Actuator on rear turbo turbine = Pre spool --> Don't have to do anything, it won't do shite once we remove EGBV
    Actuator on rear turbo compressor outlet --> Take off alloy pipe and remove reed valve and butterfly inside alloy pipe, can then remove actuator and plug lines
    That will put it in parallel turbo mode
    Wilbo's JZA80
    Wilbo's JZZ12
    Ah yep, I was only refering to the EGBV.
    I agree with you on that being the best method, I'm just thinking in this situation leave the EGBV where it is (and it won't need wiring open as it's sprung open isn't it?) for ease, minimum cost of dump & to help restrict it a bit.
    No point putting on twin dumps & big zorst then having to fit a restrictor & pulling it all off for the sanest option of single turbo.
    +1 for removing the compressor valve, and pre-spool won't matter.
    Yeah we all know the best method here it to remove the silly twins and go single... and I'm sure he will wise up to that
    Nah EGBV is closed by default, so would have to remove actuator and wire open... less effort than just removing! (It's in it own section that is like 2" thick so just drops off )
    I think his idea is to run heaps of boost on the stock turbos (No restriction, no second wastegate)) --> blow them --> causing the engine to ingest a comp wheel --> leading to forged internal build --
    I await the carnage
    Wilbo's JZA80
    Wilbo's JZZ12
    Forum Sponsor Conversion King
    I await the carnage
    provided Captain Tightarse actually runs an intercooler then it should act as a secondary air filter for heavy particles, so not much chance of doing damage.
    but then again it probly wont be running for another 2 years so atleast he would have time to save for said forged internals if the worst did happen
    no doubt...but not having any kind of boost control would just be flat out reckless
    Letting you drive anything would just be flat out reckless but that's beyond the scope of this thread.
    You can still control boost with your right foot by not letting the boost gauge go above x-psi (by reducing load and keeping rpms in check).
    Aug 2006
    this thread delivers
    hurry up with the skidz you soft c*nt!
    Didn't stop my 2j from ingesting bits of an exhaust wheel when #2 turbo went bang
    Edit: Actually, rather than "ingest", suppository is probably a more accurate term for how they got in
