Results 1 to 10 of 10
Thread: Help and info on KE70 Axle Seal Install
    Banned 1st year Apprentice
    Apr 2008
    Default Help and info on KE70 Axle Seal Install
    Hey peeps im about to whack in some axle seals to my ke70 just wondering if were looking at the assembly and or if im going to need a press for bearings or anything or if its just pull brake drum cylinder off and undo the bolts and its behind there. Anyone done this before?
    Forum Sponsor Conversion King
    Dec 2006
    Default Re: KE70 Axle Seal Install
    1. drum off
    2. undo the 4 axle retaining bolts
    3. undo brakeline to the wheel cylinder
    4. pull out axle
    5. pop the seal out
    installation is the opposite but dont forget to bleed the brakes.
    Why do you need to do that? Doesn't the bearing come through the backing plate?
    Quote Originally Posted by Mos
    As a guess the bearing plate doesn't clear the wheel cyl...
    Wilbo's JZA80
    Wilbo's JZZ12
    Dec 2006
    my bad, havn't touched a stocker in about 3yrs. no need for backing plate or brake line to be removed, therefore no need to bleed brakes either
    Apr 2008
    so no press needed for this job i can do it in my driveway right? loose fit bearings??? cheers heaps
    Bad guess
    Quote Originally Posted by Sleepy1
    An axle puller helps, especially if it's the first time the bearing is coming out... Can take quite a bit of effort to get them to budge sometimes, but yes, loose fit.
    Mos.
    Default Re: Help and info on KE70 Axle Seal Install
    "loose hammer fit"?
    Apr 2008
    Just changing the seals its pissing all over the inside of my wheel gonna do the rear brakes and cylinders too just needed to know if i had to press any bearings off to change the seals or anything cause then i would have to take it to the workshop. Id would rather just do it in the drive. Cheers for the help peeps.
    btw dont you just crank the drum on the studs backwards and wamo
    Apr 2008
    Humpty Dumpty sat on a wall i pushed him face first into the floor and WAMO!! that will teach you for trespassing you egg fuck!
  1. RA23/28 with KE70 steering column and rack and pinion
    Last Post: 24-01-2017, 03:39 PM
  2. DIY: My Celica-Supra (MA46/47) differential swap into AE86 & info.
    By assassin10000 in forum Tech and Conversions
    Last Post: 15-12-2008, 02:12 PM
  3. shortened axle on KE70
    By CHB in forum Tech and Conversions
    Last Post: 07-12-2007, 03:49 PM
  4. Hilux diff axle seal issues
    Last Post: 01-07-2007, 11:20 AM
  5. KE70 Rear Axle Oil Capacity
    By Tham in forum Tech and Conversions
    Last Post: 26-05-2006, 07:43 AM
