TA63 is pretty similar to RA65/RA60/SA63
first, find out if your *A6* is IRS...
if yes, research RA65 1jz-gte conversion and prepare for a $750 true-trac enema (brakes are also good when you give a 1200kg car over 200rwkw - recommend R33 conversion.
If the R154 is already in there, that makes your life easy - gbox mods fairly minimal. otherwise a W58 will be enough to handle the 1jz
