Originally Posted by
o_man_ra23
Check out my RA28 thread... 18R-GTE isn't too hard, and should be a heap of fun. I would suggest using a T25 turbo rather than the CT26 I used, as they are a lot easier to find for cheaper. EFI gear you can get for about $300, injectors about $150, MS2 about $400 with loom, wide band ox sensor about $150, I made my manifold for under $200 (including dump pipe), and then you have miscelaneous pipework and an intercooler, plus the fuel system, most of which would need to be done for any other turbo conversion.
Best bang for buck is 1G-GTE, but you then lose the 4cyl. 3S-GTE is my preference (which is what I am using for the RA23)
