Page 1 of 3 123 LastLast
Results 1 to 15 of 42
Thread: 4x100 +0 offset rims???
    Chiba
    Default 4x100 +0 offset rims???
    Whats avaliable?
    I'm looking for a set of 0 offset (or close to) for my rollas wide body conversion (Got dish?) and am looking for 7" for the front and 8" for the rear in 16" diameter.
    Most 4x100 seems to be around the +30 to +40 offset. I need these things to stick out from the guards!
    Any pointers? I want forged lightweight in a 5 spoke design.
    Default Re: 4x100 +0 offset rims???
    try looking at the japanese wheel makers sites. they list all the available (current) sizes..
    closest i can quickly find is 14", 6.5width, 4x114.3 in 0 offset
    all 16" in 4x100 are high offsets
    edit: if anything, you will be looking at a custom 3 piece... (or a ghey 40mm spacer )
    this is for carpark posing? what will happen to wheel bearings?
    Chiba
    Yea, I don't really like spacers....
    I can make an adapter to step the rear hub out from the knuckle, then it's just a matter of spacing the caliper brackt out the same amount to suit.
    But then I loose the awesome dish, and it's not so easy for the front superstrut....
    What about if if I go to 17"? Any chance of finding a suitiable rim?
    simmons could make some for you, failing all else
    and with 0 offset + mega dish, why do you care about weight? they're not exactly going to be ideal for the track anyway
    the problem is that all(?) 4x100's are FWD, and all FWD's have +30 or +40 offset.
    there is a small market in RWD zero offset rims (4x114.3) but nothing in 4x100 that i can see.
    ie, there will be no 1 piece forged 4x100 zero offset. the larger you go, the less likely there is to be a rim. maybe old 14" or something?
    check yahoo
    http://list1.auctions.yahoo.co.jp/jp...-category.html
    15x7 +22 http://page12.auctions.yahoo.co.jp/j...ion/p122566624
    +27 http://page6.auctions.yahoo.co.jp/jp/auction/f72063753
    Chiba
    The minimum size i can go is 15", due to the 2pot superstrut brakes.
    I want to achieve something like the pictures below, but I'm afraid they used spacers....
    you can have those in 17", 4x100, 0 offset (or less), and whatever width you want
    Jan 2008
    western australia
    jdmyard has 15*8 and 15*7 rims with 3inch dish 4*100 stud pattern and 0 offset
    andrew
    you're doing a widebody conversion to your Levin
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Quote Originally Posted by andy1827
    andrew
    these ones? http://www.mx5mania.com.au/product1508.htm
    at $200 they would be cheap china copies no? definitely not forged..
    what weight are they?
    Chiba
    Those first rota wheels look good, what's the quality like?
    the US honda guys seem to like them
    Man... where do you get front guards/spoiler like that!!!
    Current rides...
    2) White RA25ST
