Results 1 to 4 of 4
Thread: Mx10 7mgte Conversion Started
    Junior Member Grease Monkey da12nv's Avatar
    Jun 2008
    Default Mx10 7mgte Conversion Started
    Just Bought A 7mgte Imported Motor And Goin To Fit It To A Mx10...just Woundering How To Connect The Loom To A Mx10 Loom..
    Wats The Easyest Way To Do That..
    DA-12-NV
    Default Re: Mx10 7mgte Conversion Started
    The easiest way is to pay someone else to do it.
    Use a wiring diagram (easily sourced from the intenetz) and find the wires that need power (probably 5 or 6). They will need constant 12V (direct from battery), IGN on 12V (only has power when ignition is on) or starter 12V (power only when the starter motor needs it). Splice those into the MX10 loom. I can supply MX13 wiring diagram if needed (should be similar). You will also need to modify the wiring for the alternator - it will be internally regulated as opposed to the MX10 one which is externally regulated. Search and there is a thread showing you how to do that.
    I don't wire up much so I can't tell you exactly which wire needs what off the top of my head but with a wiring diagram and a lead light, it's very easy to work out.
    This is pretty much copied verbatim from a post in one of your other threads.
    Jun 2008
    wat can be dome to the auto shifter leaver inside the car? im using a ma70 auto box?
    DA-12-NV
    It's a minor detail. Bolt the big shit in and then you can sort out the minor crap.
  1. Mx10 7mgte Conversion
    By da12nv in forum Tech and Conversions
    Last Post: 29-07-2009, 07:12 PM
  2. MA70 --> JZA70 Conversion
  3. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
  4. Conversion decision!
    By twentyEight in forum Tech and Conversions
    Last Post: 30-10-2006, 07:35 PM
