Results 16 to 17 of 17
Thread: Oil Flow.
    Tallahassee, FL USofA
    Default Re: Oil Flow.
    Quote Originally Posted by af300e
    sufficient overflow capacity.
    The baffle system in question is typical, but I have built it myself.
    final issue was the mini-sump might overflow
    have sufficient drainback to the main side sumps.
    the oil from the outer sump will be constanly forced in and out of the centre sump- time to cool in the outer sump before it flows back into the mini-sump
    the pump is continuously pulling oil from the mini-sump
    I think you are over thinking the simplicity of this and putting too much into it. I thought that this was some sort of extra oil tank/sump that was being plumbed in to increase oil capacity & positive delivery or some such. If it's just baffling, I think you'd find that the same type of horizontal plates that many manufacturers use, will prevent the oil from climbing the walls works really well.
    Does yours need to be biased for a circle track?
    Junior Member Grease Monkey rick q's Avatar
    The capacity is the total flow out of the pump. The actual flow through the engine would be that less the (unknown and variable) quantity that is passed straight back to the sump through the relief valve
    Cheers ..... Rick Jones
    Fraser Clubman
  1. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  2. Bosch Fuel Pump Flow Rates
    By TheToyman75 in forum Tech and Conversions
    Last Post: 19-12-2007, 07:06 AM
  3. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
  4. Head flow thread, please post for all to see
    By Mr DOHC in forum Tech and Conversions
    Last Post: 19-01-2006, 05:41 PM
