Results 1 to 8 of 8
Thread: External Wastegate
    Junior Member 1st year Apprentice turbo_gze's Avatar
    Default External Wastegate
    When running a external wastegate do you need to run a BOV as well?
    Do you really damage your turbo if you dont?
    Under going a turbo conversion at the moment running a t28 (internal welded shut) and runnning a external wastegate on a 4agze.
    Default Re: External Wastegate
    Im not that cluey on the subject however quite a few externally gated engines i have been heavily involved with do not run a BOV. They have been succesfully doing so for a fair while. They sound like their is a flock of pigeons under the bonnet tho
    Choice of wastegate has nothing to do with whether or not you run a BOV.
    The merits of running a BOV has been discussed many times on this forum. Suffice to say they're far less important than most people imagine.
    Was there a reason why you chose the external over the internal?
    Just wanted the screaming lady at the gate?
    TAS
    Re: BOV (and without this becoming another BOV thread) - really depends on whether the sound of compressor surge annoys you. I guess some setups are different to others - on mine, it was pretty loud and really annoyed me, and I believe I noticed better response between changes once I fitted a BOV...
    Like Norbie said, wastegate type has nothing to do with BOV (are external gates really any louder if the waste pipe re-joins the exhaust?)
    better boost control for higher boost pressures,
    plus screamers are sick mayte!
    CAE86 Grease Monkey ae95's Avatar
    wastegates and bovs are for totally different purposes
    wastegate controls boost by venting exhaust gas away from the exhaust wheel
    whereas
    a blow off valve vents excess boost pressure when the throttle shuts
    apparently a bov helps reduce turbo lag during gear changes
    quite a few stock cars run them such as saabs, most turbo nissans, most turbo toyotas. i reckon a non wanky plumback one certainly wont hurt
  1. $10 ghetto spec external wastegate
    Last Post: 17-08-2008, 10:53 PM
  2. external wastegate....which one??? HELP NEEDED!
    Last Post: 07-08-2007, 05:13 PM
  3. external wastegate?
    By 2jzhilux in forum Tech and Conversions
    Last Post: 12-03-2007, 11:44 PM
