Results 1 to 2 of 2
Thread: 1jz stock turbo boost levels
    Junior Member Grease Monkey Maverick's Avatar
    N.S.W.
    Default 1jz stock turbo boost levels
    Hey boys and girls i recently aquired a 1jz cressida, and the motor has been fully rebuilt with forged pistons, head has been mildly ported and for some weird reason ebay ct12a`s were fitted. the car also runs an ems stinger. After mucking around with it cleaning up all the loose vacuum / pressure hoses (it was a bit of a mess) i got it running and the turbos were seeing about .7 bar. It went ok but i pulled them off and replaced them with the standard turbos as i`ve read bad things about shit chinese turbos.
    the car runs much better now, my question is what boost can i reliably get out of them as i want to keep the factory twins. the car has custom twin dumps fitted and also 3 inch cooler piping most of the way round.
    any thought?
    Default Re: 1jz stock turbo boost levels
    This topic has been covered several times, a search would have given you all the answers you would need.
    http://www.toymods.net/forums/showth...ight=1jz+boost
    That being said, when twin dumps, a high flow exhaust, cooler and pod are fitted, anything from 1 BAR (14.5 PSI) to 18 PSI is usually safe.
    I run 18 to 20 PSI reliably, but then you have some people too scared to go over 12 PSI... its up to you.
    JZA70|R / 12.45 @ 111 mph.
  1. **HELP** Twin turbo to single 1jz setup.
    Last Post: 11-07-2011, 11:06 AM
  2. 1JZ Not making boost?
    Last Post: 22-03-2008, 05:49 PM
  3. 1JZGTE Stock headgasket...how much boost?
    Last Post: 29-12-2005, 03:40 PM
