Did you check under bonnet fuses as well as under dash?
sounds like a circuit has failed, but the cause could be heaps of things
Fuse
Earth
Corrosion
Dodgy wiring
was just travelling home the other day when all of a sudden all my dash cuts out ( digi dash ) radio turns off and the motor had no power ( no spark I would assume )
Pulled over to the edge of the road. And this was what I found
Headlights worked
Hazards workd
Interior lights worked
Blitz sbc I colour worked as well as afc neo when ignition turned to on ( so ecu was turning on and functioning )
Tail lights didn't work
Brake lights didn't work
When I turn the key to on. It doesn't set off my car alarm or stop it from immobilizing ( but alarm still works on the doors and shock sensor etc )
Initially thought it was a fuse but checked them all and there all fine
I did plug my sub back in that morning. So perhaps that has something to do with it. But not sure cause it worked fine before
Just wondering if anyone has had anything similar. Or know where I should start checking. Iam fair stumped at where to even start atm![]()
Fuse
Earth
Corrosion
Dodgy wiring
lol cheers mate. yea i found out what it was. refer to the other thread tho cause i jsut realised iam an idiot![]()
