Results 46 to 60 of 65
Thread: 3SGTE coil on plug conversion
  1. #46
    Mar 2012
    Default Re: 3SGTE coil on plug conversion
    The daewoo Lanos coil packs usually have built in ignitors, but not all. Make sure its got the alloy plate on the back, thats the heat sink for the ignitors.
    They have pins for the spark plug leads, you can squash down normal leads to fit or get custom leads or use Daewoo leads.
    Older coild have DAE on them, newer ones have GM. I have had a couple fail, but I have installed 30? and they are cheap and easy to get.
    Some pics of some of my installs:-
    Yep that one is 25psi twin charged 4AGZE!
    -Sam
  2. #47
    Peter, the 1zz-fe (and 1nz-fe) coils are great under boost.
    I had them on my 3s-gte with 208rwkw. They will happily handle 300kw.
    ([][][]II--LT--II[][][])
  3. #48
    Forum Contributor 1st year Apprentice robk's Avatar
    Feb 2010
    I have a gen 2 3S-GTE with 1ZZ COPs. I used the kit offered by 'RacerX' in the US (which includes an adapter plate that goes on top of the cam cover).
    I'm making 353rwkw at 31psi of boost on E85, and my 1ZZ coils have have never let me down.
    1990 SW20 MR2 with '5S-GTE'.
    418rwkw @ 32psi of boost on E85.
    289rwkw @ 20psi of boost on 98 RON.
  4. #49
    Jul 2007
    what dwell time you running on them rob? I've killed two 1ZZ coils now at 3ms dwell, on wasted spark, my mate also killed two, now dialled back to 2.5ms and seem to be ok for the moment, but he hasn't really put many kms on it yet.
  5. #50
    Feb 2010
    I think mine are at 3ms dwell, but I can't remember if I ever reduced it. I'll check my ECU tune file later.
    I'm running full sequential ignition, so that could be making the difference in longevity.
  6. #51
    Jul 2007
    yeah i'll be going full sequential on the next setup as i suspect it may not be helping things as well..
  7. #52
    Nov 2011
    i think the aftermarket chinese sheit 1zz type coils are the ones that play up
    ive seen a 1j with these coils on the dyno and it stuffed up 2 or 3 coils and when we pulled them out they looked cheapish
    so we got some 2nd hand original ones from a camry I think and was able to dyno it more
    these days we just fit ls1 ls2 coils to everything
  8. #53
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    28 and rob k thanks for that info it will surely help me when i get around to putting the car together
    Cheers, Peter
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
  9. #54
    Jul 2007
    Quote Originally Posted by dumbass View Post
    We killed two cheapy ones and two genuine ones between us. I hear you on the ls coils. They are bulletproof. But they're so shit to install neatly!
  10. #55
    May 2011
    small thread hi jack.
    tried starting my car with a base map, set the timing etc and no luck. have spark and fuel pressure. so I have one question.
    when running COP is it possible to set the timing 360' out?
    ie its sparking on exhaust stroke not power/compression stroke?
    I believe it is and all I have to do is pull the dizzy and turn it 180. (results as 360 at the crank)
    any way to confirm im out 360" apart from removing the valve cover?
    oh and the timing is set to 10" with locked timing on the ecu and it ligns up with 10" on the crank MARK
    1990 ST185 Running stock Gen 3 power, 216awhp at 15psi. 13.6 second down the quarter
  11. #56
    Jul 2007
    you could have the coils wired up in the wrong way so that they are not firing in the correct order. you can have the timing out if you put the dizzy in on the wrong TDC. you want TDC for compression stroke on cylinder 1
  12. #57
    Feb 2010
    Quote Originally Posted by aus jd 2703 View Post
    Yes it's possible.
    If you're running wasted-spark then it doesn't matter, but if you're running full sequential ignition then it does matter.
    If your timing looks correct compared to the mark on the crank, then you're either correct or possibly off by 360 degrees.
  13. #58
    Feb 2010
    Quote Originally Posted by robk View Post
    I just checked my ECU settings and yes my dwell time is set to 3ms for my 1ZZ COPs.
    I think I'll just leave it like that, as it would be useful information to see how it goes in the long term anyway.
  14. #59
    Nov 2011
    Put timing mark on crank pulley at 80 degrees ATDC
    I think that's right
    Then put timing light on cyl 3
    Timing mark should match up to the 80 ATDC
    If u get stuck and around Gold Coast or brissy area and need to pay someone to fix it or get it going let me know
    I do this shit for a living
    Honda cbr motorbike coils are good to but u need a CDI to drive them for best results
  15. #60
    May 2011
    Fixed tooth offset was the issue! I'm an idiot for forgetting to adjust it. Runs now
  1. MA61 5me to 5mge conversion guide
    By Enchanter in forum Engine & Driveline Conversions
    Last Post: 17-09-2013, 07:07 PM
  2. pressure tested and problems
    By 2revup in forum Tech and Conversions
    Last Post: 18-02-2008, 04:11 AM
  3. MA70 --> JZA70 Conversion
  4. Coil for High Energy Ignition
    By Tham in forum Tech and Conversions
    Last Post: 24-05-2006, 01:29 AM
  5. checking timing on car with coil on plug setup
    Last Post: 23-02-2006, 07:52 PM
